Liners move, blocks flex. Crank not such a problem - big and heavy compared to some of the stuff out there.Zamani wrote:Is the main problem only the liners not being stable due to the fact that they are removable and open deck at the top? Epoxy? The rods can be fixed without too much expense. What about the crank? Too wobbly? Why? By design and construction? main bearing caps not sturdy enough?
You can of course go the Jim Steck/Alfaholics method to sort the liner movement, but gets spendy quickly.
