Hi,
How much more cooling does a stock 2V2.5L require compared to say a moderately modified 2L four?
The reason I ask is because a present I have a heavy duty 4 core Austin 1800 radiator cooling the 4 and it does an admirable job, even on 40 degC plus days, but upgrading to the V6 I'm afraid that it may not cope.
The cooling area of the Austin radiator is quite small, 360 x 360mm, 50mm thick with staggered cores and I don't have the room for a larger unit.
Cooling a stock 2.5V6
Brett
Cheers mate.
I really can't go any wider than what I have but maybe 50mm taller, no more.
The Austin is a very efficient radiator as they were mounted sideways and therefore didn't get a lot of airflow. They were used a lot in racing many years ago (the radiators not Austin 1800s
I guess what I'd like to know is. Is the GTV6 2.5 radiator much bigger/thicker the the GTV4?
Maybe someone here has been crazy enough to try a GTV4 rad with the 2.5 and found that it ran just a little hot but didn't turn into a kettle.
If that's the case then the Austin would probably be ok.
Brett
- Rookie ROX
I'll chime in and say that my mildly modified 2.5L has never had overheating problems since I've had it over the past 3 or so years. It's using a stock radiator and fan. The only thing I did was have it sent away to be cleaned when I initially got the car on the road - But it's quite happily coped with the past few summers of 40 degree + temperatures. The only other thing I have done is wire in a fan temperature controller that allows me to remotely set the temperature that the fan turns on - It was simply to allow me to rely on something more accurate than the standard temp sensor though.
ROCK ON
R~R
ROCK ON
R~R
