24v Cylinder Head Gasket Kit - Where to buy
Ok Well my 24v project is undrway again - next step is to buy a complete Cylinder head gasket kit and engine gasket kit - which apparently includes the oil valve stem seals as well.
Part numbers are 71713723 Cyl and 71713724 eng.
Can anyone advise where would be the cheapest place to source these kits from, Alfa australia thinks they are made of gold or something and prices them accordingly.
PanchoRama
thanks sportuner, its a 166 3L though. Not sure if there are differences, but there would some minimal ones for sure.
Thanks, B. I will see if I can catch him on here, or if you would be kind enuf to send me his email addy.
PanchoRama
Sorry mate,was a bit vague here..Kevin at EB Spares in the UK..pancho wrote:thanks sportuner, its a 166 3L though. Not sure if there are differences, but there would some minimal ones for sure.
admin@ebspares.co.uk
Bb
Ah yes, now I understand.
He says he has aftermarket complete engine kits available for 150 pounds but no original alfa kits in stock. Is original better than aftermarket ?
What would you do Barry ?
Go original or aftermarket ?
![Question :?:](./images/smilies/icon_question.gif)
PanchoRama
Id get 2x REINZ headgaskets ..All the others can either be reused(cam cover rubber seals and plug seals)or gray Loctite siliconed..(water pump and thermo housings,etc..)
If the rubber plug seals are hard,get those as well..
Btw,REINZ is OE here..
If your using 164 type cam covers,chances are the old 4 piece gaskets are shot as well..Get those as well then.Your 166 based?Its got the newer ,better runbber sealss..
expensive maybe but not OEM expensive !
engine gasket kit 181 pounds
head gasket set 166 pounds !
so AU it would have been over $880Au
I got my full engine set for just under $400 and they were in stock - so I am very happy.
Thanks for the help guys.![Very Happy :D](./images/smilies/icon_biggrin.gif)
PanchoRama
