You guys are confusing the hell out of everybody here!!
How's a guy supposed to write a book and suggest solutions when there's so much controversy regarding tensioners?? Dennis had 3 croak in a few months
and I've had mine in for 8 years now, no problems! Before that, I had the factory one with the constant leaks even after two rebuilds. I then plugged the oil lines and ran it dry for a year before getting the new style one. For a while now, reading all these experiences I have come to think that a modified stock unit is probably the safest solution! So (to keep Dennis happy too
)this is just what I will suggest: Modify the std one! I may have been one of the lucky ones with the new unit. 3 years ago, I ordered one for another friend here with a 3liter and the damn thing croaked last week, so I think the verdict is obvious.
Confusing topic indeed. My experience with the original hydraulic tensioner came from my previous 164 3.0. Constant leaks and constant worries even if it was serviced several times. So when i purchased my GTV6 and previous owner said tensioner was "rectified", at first i was thinking; good ! But then when i saw how it was actually rectified i begun wondering ; can this be good for the timingbelt ? No detensioning would probably mean more strain on the belt i thought. So i decided to purchase the new and "improved" tensioner. But hearing all the warnings now, i'm again a bit worried. But as a way to gain own experience on the new tensioner, i think i will try this setup for my self now first, and see how it goes.
But thank you all for your advise and i will take note of your recommendation to keep the old plugged tensioner, as it perhaps is the best setup of them all.
Hi all, I am in the process of installing the new type cambelt tensioner and I have come across a web site you all may find usefull.
www.alfapro.com/htm/tensioner_install.html
I hope this helps.
Paul. GTV6
I hope this helps.
Paul. GTV6
- Dennis
It's very confusing indeed! I went with the mechanical tensioner because I was fed up with the leaking original one. I installed everything according to the manual and adjusted it perfectly. Checked it a couple of times after turning the crankshaft by hand, tension was just beautiful. It was OK for the first couple of days and then it would skip a tooth on warm start-up.
This happened to me a couple of times (allthough the spring hadn't snapped every time), and avoiding this resulted in over-tensioning the damn thing. That didn't comfort me much, so in the end I installed the original one (without oil) again. Untill today this always resulted in good tension on cold and on a hot engine, never a failure in 10000 km. I'll never go back...... not even a 100 succes stories can do so.
I packed it with grease to give the piston inside some resistance. In theory when the engines warms up the grease will get a bit thinner and will ease off a bit of tension. Just like the original one. I don't know if it really works that way, but I know it works a hell of a lot better for me then that crappy mechanical one.
Thanks for keeping me happy, Jim
'81 GTV6 3.0 QV
'91 75 TS (track)
'02 BMW 330i Touring
'91 75 TS (track)
Just to be clear...If you EVER have your engine jump time with the 'new' style tensioner, DO NOT just reset it. Replace the tensioner and destroy the 'skipped' one. It doen not matter if the spring is OK or not. I have had a lot with a broken spring that worked fine, and skipped ones that looked perfect.
Mechanical type tensioner failed on me on monday. Luckily all valves are good. I reinstalled the plugged hydraulic type as per advise
I started the engine up and let it heat up to operating temp. Now the belt is very firm. I think it's maybe too much thension. What should be the install tension at cold engine, so that the belt is not overtensioned at warm engine ?
timing belt tensioner
this has been an interesting thread to follow!
what is the part number for the older ( and recommended) tensioner?
also where is the best place to buy replacement bearings? is it a common size or does it have to come from IAP or similar?
thanks
ben
thanks
ben
1962 Giulia Ti Race-car
1969 Giulia Super
1987 GTV6- new race project.
1969 Giulia Super
I just bought a old style tensioner from Larry at APE. He does have a few more, but its not like they are coming out of his ears. He also has one GTV6 parts car, 4 or so Milanos, 2 Montreals, some early GTVs, some spiders, some parts and some runner v6 engines, etc.
His phone is 209-833-8330. he is a one man operation so he isnt always by the phone but will call you back.
hth
Scott
hth
Scott
I posted this on gtv6.org 2 years ago...same topic,same confusion..
The problem with the "new " type tensioner on the old type motor is the fact that the old type motor runs a very shallow squared off timing belt setup..When fitting the "new" type tensioner,it has way too much movement and the ability to move through this range very easily..
The answer here is to limit the movement of the pretensioner part so the it cannot give enough for the belt to jump..I simply drilled 2 holes either side of the fulcrum "leg" ,fitted 2 x 4mm bolts about 25mm long to act as stoppers...these act as stoppers ..it works fine then..
Other than that,when used on the 155 type belt ,the belt has deep half round teeth that need a lot of freeplay for the bely to jump..the "new" type tensioner goes hard against th stop before this belt can jump..
So the cure here is to limit the travel or use the old type designed for that square belt..
I was not aware that the new tensioner was intended for a different type of belt. Guess that explains the poor performance of that particular tensioner on the older engines. Barry; i think it was you who had the good rule of thumb for tensioning the belt with the modified old tensioner in another thread. To install it so that it can be turned 90deg on the longest portion. Works like a charm. For me the switch back to the old type tensioner has been great. I drove the car from Norway to Nurburgring in Germany. Drove hard both both on the Autobahn and on the track. No mechanical problems, and just a lot of GTV driving fun
