I am currently undertaking the "swap" of the (1990) 75 TS Box into an (1981) GTV6.
I have sent the 75 TS gearbox away to have bearings replaced so I am a little confused at the minute.
Firstly the wheelbase is different on the transaxles. i.e the 75 has a wider wheelbase.
My question is basically:
Should/Can I fit the LSD gearbox to the original transaxle and use the GTV6 driveshafts & brake disks with the spacers (Will that actually work?) or can I simply fit the entire 75 gearbox/transaxle/anti-roll bar system directly into the GTV6, therefore using the longer 75 driveshafts?
Help is much appreciated.
Johnny
