I have an '82 GTV6 2.5 all stock,except for a complete engine rebuild 1500km ago, with the 0-280-001-113 ecu in her, but the o2 sensor(Lamda) lead has been touched against the 12v starter motor source (on the fire wall), instead of lead in one hand and touch the 12v source with the other hand
A new O2 sensor has no effect and it feels like its flooding, boggs down in the beginning of first gear. Over 2500-3000 rpm its fine, and the other gears are ok. Starts and idles great.
So now Iv'e slipped in this euro ecu 0-280-001-117 (UK source), AHHHH what's that noise!!! grumble,burp,pop ....Got it warmed up and it idles ok , but bucks and lurches, oooh my poor old clutch.
Is the circuit that different on the inside? I checked the GTV6.ORG archives but didn't catch much except for a bmw spec. ecu upgrade. Are the temp sensor and AFM pins in the same position on our US versions?
This has only been a 15 min 7km test run without adjusting the timing. So I'm gonna coax her back to the shop tonight and fiddle with that, and maybe the vacume advance mechanism.
Thanks for any help, Glen
