Which ljet boxes are the same as the Alfa´s?
Which ljet systems are interchangeable with ours? I would like to buy one so that I may use the wiring harness to connect to the MS that I have not yet purchased/assembled. I am sure that I have read this information on the board, but I cant locate it right now.
Oh, and while I am at it I guess I will ad another silly question: With the MS pigtail, how do you connect to the car´s wiring harness? Or do you connect directly to the wires?
I don't have a complete list of cars with similar L-Jet, but several BMW's from the late 80ies have them. Other European brands as well, like Opel and Fiat should have them.
I made a pigtail to connect to the L-Jet wiring harness. I took the 35 pin Amp connector out of a broken L-Jet case (from a Fiat) and soldered wires to a DB37 female connector in one end, and spade connectors to couple them to the Amp(L-Jet) connector in the other end. I hade a reversed signal on the TPS, so the spades came in handy, as it was just to re-plug the wires.
The Amp 35 pin plug is difficult to get hold of, so the scrapyard is your best option.
The problem with the pigtail solution is that space is limited, so it is wise to make the leads as short as possible in order to get the thing to fit into the GTV-6. I need to shorten mine.
Hear's how I did my install on the L-Jet socket from an old L-Jet case. There are plenty of cars that had them. Leave the L-Jet wiring harness in the car as is.
http://www.alfagtv6.com/bb/viewtopic.php?t=219&start=30
I also soldered the wires to the L-Jet pins. They are easy enough to change if you get them wrong.
David
David
Really nice work on that adapter, David. If it is possible, could you make a dimensional drawing of your mounting plate ? I would like to copy your work there. I'm currently re-working my adaptercable, with shorter wires, so i can get it to fit inside the L-Jet compartment. I had the MS box hanging in plastic strips as a temporary install, but now that everything works, i can solder everything and make a permanent install.
P.
P.
L-Jet boxes
I know this is not exactly helpful, but I am pretty sure that there are Audi and Volvo ECUs that mate to the GTV6 L-jet connector. I used an Audi one (I think) for my prototype L-Jet adapter, and it had a pretty cool brushed aluminum cover. I kind of troll E-Bay for ones with pictures that look right, and if they are really cheap, buy them.
-Al
-Al
Al Mitchell
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Reale Motorsports
#82 E Production
Alfa Romeo GTV6
Zamani, I bought on ebay a ljet box so I could sacrifice the header for my MS project, but it turned out not to have all the header pin/connectors. So when you did an ljet box, just make sure it has all the pins (readily visible on the outside of the box). If all you want is the header, all the lject boxes use the same type of connector...I think.
Good luck. Welcome to the fray.
Bill in Maryland, US
Bill in MD
'88 Alfa Milano Verde x 2
'77 Fiat Spider
'77 Fiat Spider
here is the item description for the box I "won" on the ebay...
BMW 328 Bosch L-Jetronic ECM/ECU. Remanufactured by ProgRama. Bosch part number 0 280 000 328. BMW part number 13 61 1 466 343
I dont know much about BMs, it never occured to me that it might be a motronic ecu.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWN%3AIT
What does it look like to you?
turns out that the ebay bmw box was the wrong type. Luck was on my side, however, as the seller was Al
He was able to set the record straight for me and he even refunded my $1. What a guy
Another board member set me up with a different bmw box so I am ready to go. I have my boards and almost all of my digikey parts. Will begin soldering very soon.
For the record:
As I currently understand it, the boxes from the early 80s 7 series and 6 series bimmers are the ticket.
Hope that helps the next guy.
For the record:
