GTV6 or 75 12v V6 CSC tubular manifolds, into twin 2" pipes going to a single box where the twin pipes merge into a single 2.5". Then turns left, through a wide flat section to clear the cross member with a bit more ground clearance, exiting as a single 2.5" upturned pipe.
Very loud, but sounds great to my ears - this is in a tunnel on the way to Le Mans a few years back:
http://www.youtube.com/watch?v=4iEai0_p ... e=youtu.be
Minus points are twofold:
Reduced ground clearance where the centre box has picked up several bangs and scrapes (still intact though),
The neighbours might not like the volume!
Selling as the manifolds won't fit the 24v about to go in so I have the change it anyway. Whilst doing so I'm aiming for a little more ground clearance so it doesn't catch on some nasty local speed humps.
On ebay, in Southern England:-
http://www.ebay.co.uk/itm/Alfa-Gtv6-75- ... 2323beb8e2
GTV6 CSC manifolds and side exit system
