Tie rods INNER
Can you use the driver side (left in USA) inner tie rod on the passenger side as well???
Anyone know??
Anyone know??
Re: Tie rods INNER
I can dig through my receipts from last year - but I am almost dead sure you can, and remember someone either at IAP or Alfa Parts that said you can do so... I'll check tonight through the receipts. GV
20-Years-3-Motors-Later
Re: Tie rods INNER
Thanks..it would not make good sense to use different rods from manufacturing /repair perspective..
Re: Tie rods INNER
Re: Tie rods INNER
Or storage, or ordering, or...
But then again it's Alfa.
Re: Tie rods INNER
Mats, do you know if they are side dependent?
Re: Tie rods INNER
Well - I dug through the receipts envelope and I can't find my invoice. When i rebuilt my front end the other year back I went to three suppliers to get everything I needed... Centerline, IAP and Alfa Parts in Berkeley. As I recall Moog makes inner tie rods.... GV
Also if this helps: viewtopic.php?f=10&t=2271
Re: Tie rods INNER
I've been running that tie rod since that post that GregoryV mentioned...it works fine, plenty of thread engagement.
Re: Tie rods INNER
WOW. Thanks! great link.
IAP sells the inner rods for 50$ each. MOOG part is ~64$. MOOG usually makes some pretty good stuff. I really like their CV boots.
Re: Tie rods INNER
Re: Tie rods INNER
Re: Tie rods INNER
Hey radicool. Hit the button ONCE , just ONCE, only ONCE man...
Re: Tie rods INNER
Ummm...no shit.
It is the way this website works for me.
It locks up unless I click it a few times...
Re: Tie rods INNER
well, it worked that time...
