I have a fully built and functional MegaSquirt. It is mounted in a Bosch L-Jetronic case which makes it perfect for L-Jet cars. It also has the flyback board installed in the case for L-Jet low impedance injectors. Because its in an L-Jet case it will bolt into your orginal EFI computer position and will just plug right into the wiring harness. It has also had the necessary fuel pump circuit modification done to it.
Simon's (Hollywell) Alfa 75 3.0 V6 ran perfectly with this MegaSquirt and he got it somewhat tuned through the rev range.Simon had it running with MAPdot but it will come with a Vishay TPS (from FarnellOne group buy) so you could run TPSdot.
What your getting:
* Complete and functional MS in L-Jet case with FlyBack board installed and functional
* Air/Water temperature sensor.
* Variable Resistance TPS with mounting plate for Alfa throttle body
* Stewart/Aussie stimulator which is functional and complete
* Serial/null modem cable for PC or PDA connection
I have a few questions that I am hoping you might be able to help me with. This will be going into my stock daily driven Alfa 75 2.5.
As a newbie to programmable EFI, how suitable is this setup given that I haven't built it or experienced troubleshooting it?
It seems to be setup for MAP(with partial MAP tune) but also comes with a "Vishay" (brand?) TPS with adaptor plate to fit TB. Would it be best to try and make the TPS thing work or just setup up a MAPsensor and use the MAP tune?
I am looking at this conversion for a few reasons. Simplicity, reliability, easy starting, and improved economy(about 12-14 l/100km in my 2.5 L-jet car
How "plug and play" is this? I understand I'd have to wire up an air temp sensor, and maybe a MAP sensor, much else?
How intuitive is MS in self tuning (if at all)? It runs in closed loop I presume but the mixture has to be set pretty much spot on doesn't it?
Any help is much appreciated.
Thanks, Scott
