Hi!
I'm currently in the process of megasquirting 33 with 16V boxer. I've been able to get engine running with MS controlling fuel and spark.
http://www.youtube.com/watch?v=Vhbv4XYg ... ed&search=
I'll use LC1 wideband to tune VE map. Because of characteristics of this engine I'll use Hybrid Alpha-N.
Has anyone done this on this engine (it's stock for now). Can anyone provide me with factory (or modified) ignition map ?
Best regards,
David
David I can't help you specifically with your 33 engine,but here is an Excel file that allows you to create an ignition map based on a few inputs.I took it off the Megasquirt site and it seems to do a pretty good job.Needless to say,when you're building an ignition map you have to be very carefull to avoid pre-ignition so listen very carefully for "pinging".
- IgnitionTimingEstimator Modded.xls
- (48.5 KiB) Downloaded 785 times
