http://www.banks-europa.co.uk/cars/running_gear.htm
Could something similar be used to ditch the De Dion, and end up with out board brakes? Obviously, the shock mounting would have to be a bit different, and maybe some work with the half shafts to get it all happening correctly...
Coupled with a Colotti Straight Cut, it starts to open up some real options for the Twin Turbo guys, and as it is, could make a bit of difference to the car's abilities on bumpy roads...
Ideas?
I briefly Remember Ben Bishop talking about the New Corvette having a rear mounted, transverse leaf spring -sprung T56 with a diff off the output shaft... any ideas there?
