Powerfull Headlight Upgrade Kit For Sale
Headlight upgrade kits for sale.
I have three GTV6 headlight kits I am selling at an introductory price of $100. This is a GTV6.com ONLY price and when these three are gone the price is going way up as it takes a lot of time to make them, longer than I thought.
The kits include two outboard lights with 55w/60w bulbs (that's the max legal amount in U.S.) Brighter bulbs can be fitted. The kit includes relays all wiring, fuses, etc. The high and low beams are independently fused and the relay system uses a factory headlight fuse. The relays can handle 75 amps each and heavy gauge copper wiring is uses throughout so you can upgrade to higher wattage bulbs and or more powerful inboard lights. All connections in the wiring harness are crimped and soldered for a reliable connection.
It has three advantages over the stock system. First it replaces the outer lights with much more modern and powerful units. Second it provides full alternator voltage to all 4 lights so the inboards will be brighter after installation. Third it eliminates the heavy electrical load on the steering column headlight switch greatly prolonging its life.
This lights included have a great pattern and if damaged they can be replaced for $25 each (less the bulbs). The system is compatible with other types of lights like Hella H4s so if you want those you can use them. I prefer the included lights myself.
Oh and shipping is $15 in the U.S. pay pal is misty@hiperformancestore.com . At this time I have no plans to make a RHD version
