Hello
Have anyone used the stock triggerwheel on the Milano 3.0 QV (Motronic 4.1) (same as 164 3L) to control spark with MS2? I haven't counted the teeth yet, but I see there's missing two teeth right beside eachother..
That is a 60-2 wheel. It is used for crank angle only instead of the Hall sensor. Just 2 different ways to skin the cat. Both use a Motronic ignitor as found on the 164 to set advance. They have a fixed dwell.
Not sure if MS-II has the custom teeth feature. MSnS-Extra code V0.24s and above has it. You can program the number of teeth right into MegaTune.
-Peter
-Peter
