the stated: Our windage tray bolts to the main bearing studs and sandwiches between block and oil pan. This adds great rigidity to the main bearing caps.MD wrote: I think tying into the big end mounts may be some advantage. Otherwise seems ok to me.
A folded plate can't add rigidity. Is only rigid in the direction the fold runs, so only gain will be in axial direction, so why bother.
The Mike Valant version is for a nord and won't fit a ts bottom end.
TS is slightly different in dimensions.
I need to dig.... but I have converted the Valant version on paper to a ts version, never proto build it though.
