Make sure your O2 correction settings are whacko. I usually do 12% max in 2% increments and 36 ignition cycles. Also make sure you are set to WB02 in the constants screen and the crossover voltage is correct. MS might be misenterpreting the WB input based on parameters.
-Peter
