Because I detected a "rattle" sound in the clutch when disengaged at idle, I decided to replace the front and rear shaft bearings. When the clutch cover was disassembled I discovered that the O-ring (shown in the shop manual) was missing allowing the spacer between the 2 bearings to rattle. My question is:
What is the size of the required O-ring?
