Page 3 of 4
Re: middle guibo
Posted: Thu Apr 15, 2010 5:39 pm
by Corne
here in SA a mechie suplied me with a giubo from a ford sierra XR 6 for my Alfetta
it worked fine
just my 2 cents
Re: middle guibo
Posted: Fri Apr 16, 2010 4:40 am
by xrad
Corne: do you have a part number or year?
Did he replace the MIDDLE coupler..or one on the end?
The merkur xr4 coupler looks like the front or rear alfa version but does not have the center bushing guide....
Re: middle guibo
Posted: Fri Apr 23, 2010 11:34 pm
by Corne
No prob i will go to thier shop in the week and speak to the chap and see if i can get the part number
Re: middle guibo
Posted: Sun Apr 25, 2010 9:54 am
by xrad
Thnaks for the offer, but don;t do it on my account. I just picked up a box of mixed guibos in pretty good condition.
Re: middle guibo
Posted: Wed May 30, 2012 3:04 am
by Alfa GTV6 NZ
Hi Guys,
Sorry to dredge up an old post, but has anyone had any trouble using the BMW part?
I just thought you guys may have some feedback after a couple of years of use.
Any thoughts as i am due for a replacement and centerline don't have any and IAP are $182
Thanks
Karl
Re: middle guibo
Posted: Fri Jun 01, 2012 1:35 pm
by kevin
If you go to link in track and race car - budget race car born ( slow delivery) pg33 you can see a BMW coupling . I use it all the time as we can't get the original but the BMW part ( genuine part) is far stronger . It's 28mm compared to 23mm so if your really want perfection then you shorten rear section of prop by 5mm . I always do but most guys here don't bother but Their motors also push out 75 kw less than mine so i like to make sure everything thing is perfect to avoid failures . ( yep and also no failures in two years on prop).
I can't post link from iPad as it normally attaches something else
Re: middle guibo
Posted: Mon Sep 22, 2014 6:09 am
by SimonB
I wish I'd read this before, didn't know what a "guibo" was. Ok, I will look for a BMW one and see if it is much cheaper or maybe its just worth £89 + VAT to get an original one.
Re: middle guibo
Posted: Mon Sep 22, 2014 1:15 pm
by SimonB
Wow! Ok, so this is the one?
http://www.ebay.co.uk/itm/New-Febi-Join ... 56681a255e
And it is stronger, cheaper and won't hurt anything? Do you think the garage will freak out if I propose this?
Re: middle guibo
Posted: Mon Sep 22, 2014 2:43 pm
by kevin
Make sure its an original BMW part as the grey market ones have no windings in them and just explode after one hard acceleration .
Re: middle guibo
Posted: Mon Sep 22, 2014 10:46 pm
by SimonB
The one I saw is Gebi-Bilstein (made in Germany) what do you think?
Re: middle guibo
Posted: Mon Sep 22, 2014 10:54 pm
by kevin
Sure its fine . We just got a lot of fake ones in SA which was probably made out of Goji berries or moulded on the same paddi
Re: middle guibo
Posted: Thu Sep 25, 2014 12:56 am
by SimonB
Just to be totally neurotic, here is the spec. Should I buy it for 36 quid?
Part Specifications
Part Number: OE-26111225624
Required Quantity: 1
Quantity Included: 1
Fitting Position: Front
Inner Diameter: 40 mm
Material: Steel Elastomer
Number Of Holes: 6
Outer Diameter: 110 mm
Pitch Circle Diameter: 78 mm
Thickness: 28 mm
Is this the right one?
Cheers!
Re: middle guibo
Posted: Thu Sep 25, 2014 2:07 pm
by kevin
As they say they the original part is always best as it its 5mm thinner but I hear there no more centre alfa guibos ( couplings , Flexi discs doughnuts ) in stock at leading Uk Specialists . A mate of mine said he just bought the last three and from now on its the thicker ones . He might be misinformed .
The specs are correct but can't vouch for quality - that's the risk you take .
If you normally struggle on that car fitting the rear of the prop onto the clutch yoke then you might have to loosen the crossmember and bring the two up together when join the rear section .
Let us know how it goes .
Re: middle guibo
Posted: Tue Sep 30, 2014 1:51 pm
by SimonB
It should come tomorrow, I will let you know how it goes...
Re: middle guibo
Posted: Wed Oct 08, 2014 2:30 pm
by SimonB
It worked fine! Garage said it was no problem to put on. Really pushed on the way home and all was sweetness and light. So far, so good. Thanks for the tip!
