Worn Gearbox or Pressure Plate?
Posted: Fri Sep 28, 2007 9:55 am
About two years back my old gearbox went crunch and lost 2,3,4 gears. Larry Jr. at APE grabbed another 83 gearbox for me and went through it just to check it over and replaced a few syncros - when it went back in the car it was awesome ... the car never shifted so well.
So now almost overnight it has gotten much worse - it's real ratchety when putting into and out of any gear, regardless of rpm or shifting up or down. No leaks at the clutch slave, Milano (75) clutch assembly has about 70K on it and disk is still looking good (I didn't change the disc when the gearbox was done because there was plenty of meat on it still). Anyone have any thoughts ... maybe the pressure plate isn't doing it's job anymore?
I can live it for awhile, but if the gearbox is still fine and it's the clutch I'm going to wear the gearbox synros out right?? Or does it sound like it could be something in the gearbox?
any experts advice is welcome!
GV
GV
