Thing on top of Diff
Posted: Wed Aug 08, 2007 3:18 am
by tmundy
Got a strange one.
On the top left hand side of the differential is as round thing that is rusty colour. In the first picture below you will see it is reasonably dry. In the second picture taken a day later there is a nice pool of gearbox fluid. Worth mentioning that I drained the fluid a couple of weeks ago. Any idea what this thingy is?
Posted: Wed Aug 08, 2007 3:30 am
by x-rad
I think it is a clogged breather and should be sticking up about 2 cm.
Posted: Wed Aug 08, 2007 3:36 am
by tmundy
It is sticking up about .8cm above the surface of the transaxle. Does it breath through the top or from the bottom (out the sides)?
Posted: Wed Aug 08, 2007 3:37 am
by tmundy
Posted: Wed Aug 08, 2007 3:39 am
tmundy wrote:It is sticking up about .8cm above the surface of the transaxle. Does it breath through the top or from the bottom (out the sides)?
Say what? out the sides?
I think you need to take some pics that give us the general overview because it sounds very confusing.
Posted: Wed Aug 08, 2007 5:51 am
by patzo_3l
early transaxles stick out a little bit roughly .8cm as u describe wheereas later cars stick out alot more. it is an oil breather and if oil is spilling out id have a guess and say u put too much oil. clean it and make sure it is not blocked.
Posted: Wed Aug 08, 2007 6:15 am
by tmundy
My car is an 83 (MK3 I believe), would you class that as early or late.
Funny thing is I drained the oil about two weeks ago before removing the transaxle. The gearbox is curently empty. How does it come of, is it screw fit?
Thanks, Tony
Posted: Wed Aug 08, 2007 10:30 am
It's supposed to be "filter" looking like wires all tangled up, your breather looks like it's filled with dirt or something.
