Very weird coolant leak WTF?
Posted: Tue Sep 16, 2008 12:15 pm
by PietereQ
I stumbled across this one while doing my 164 alternator conversion.
As i was removing the alternator adjuster mount, when I removed the bolts, coolant started dripping form bolt holes, shortly after i had a puddle under my car. Anyone seen something like this on these engines
Re: Very weird coolant leak WTF?
Posted: Wed Sep 17, 2008 2:00 am
by Murray
PietereQ if I remember correctly one or more of the bolts which fasten the alternator bracket also serve to fasten the water pump to the cylinder block,so either the pump gasket requires replacement or it will simply reseal itself when you re-attach the bracket.
Posted: Thu Sep 18, 2008 10:09 am
by PietereQ
I took a look at it today and I don't think the water pump "goes so far", or at least i didnt's see any part of the pump near the bracket. I have teflon-taped the threads, and hope it will be good for the time being
Posted: Thu Sep 18, 2008 5:29 pm
by Daniel
That's definitely the water pump behind that bracket.
Seal has or is failing.
A pain to do it but now is better than on the side of the road.
