car bogs when gas is pressed down too far
Posted: Thu Oct 13, 2005 8:24 am
by grega
hello all.
My car's been bogging when i hit the accelarator pedal to fast.
Any ideas what it could be?
Greg A.
83 gtv6
Posted: Sat Oct 15, 2005 2:59 pm
by grega
Could this be caused by the throttle switch?
Posted: Sun Oct 16, 2005 12:25 pm
"Sport" filter?
Posted: Sun Oct 16, 2005 4:16 pm
by grega
i have a K&N filter, it's the kind that goes in the original housing.
Why??
Posted: Sun Oct 16, 2005 11:41 pm
Have you tried a std paper filter just to eliminate that possibility?
Posted: Mon Oct 17, 2005 8:09 am
by grega
i have the old one i can try. What is the reason for the performance filter causing this problem? is it a common prob? I also should mention that the car doesn't always do this. And it seems to be worse when the car is cold
thanks
Posted: Mon Oct 17, 2005 2:28 pm
by Zamani
Weak spark? Retarded distributor?
Posted: Tue Oct 18, 2005 7:48 am
by grega
the car only does this when it's driving, so how would i check for a weak spark or the distributor?
SPARK AMPLIFIER AVAILABLE
Posted: Mon Oct 24, 2005 7:50 pm
by alfaprince
I HAVE COUPLE OF SPARK AMPLIFIERS AROUND $40 REAL DEAL EMAIL
MTORRENTE@FLYANDFORM.COM. I ALSO HAVE A SPARE FUEL PUMP YOU MIGHT WANT TO TRY THAT $50.
Posted: Tue Oct 25, 2005 7:21 am
Sounds like it's running really lean. Look for air leaks.
