Fuel filler neck
Does anybody have a source(alfa or not) for flex fuel coupler at filler neck. The IAP one is too short.
Thanks.
Sporttunergtv6
Post by Sporttunergtv6 »
iap loves the cock on that one... mine was too short too and they said they would get back to me on it. never happened. oh well they are good with just about everything else.
GregoryV
Post by GregoryV »
I went through this one about two years back - not available from anywhere (that I could find at that time) except IAP. I purchased the one from IAP, and also called them after discovering it was short.
My old one was really shot to where I didn't feel safe even putting gas in the car, so it was fix it or park it. I ended up removing the filler neck and had it extended by a local metal fabricator by a few inches ... then the IAP one worked just fine. You'll want to measure everything out proper - remove the old coupler then attach the IAP one to the tank side, and measure how much longer it needs to be. The cost for the metal fabrication was darn near $100, but they did a class job, no weld seam, no leaks.
Gregory V
Martinez, CA
