Wipers: no high speed
85 GTV6...intermittent and slow speeds work fine. No high speed wiping, just stays at same slow speed with switch in high or low position. Any ideas?? Thanks.
Burger
Post by Burger »
Itz probably your combination switch for the wipers.Every Italian car I've owned has had that problem.
Thanks, I will check the switch. The door lock came together just fine, thanks for the parts!! Maybe I will need a combi swith from you soon.....
