Kerry
no turn indicator(milano)
Post by Kerry »
can someone help, my right turn signal is not working, bulb is good, the light flashes with the emergency flashers but not as a turn indicator, the left signal is working fine. Its too cold here in Michigan to use hand signals so Im making some people angry, any ideas? 87 Milano! THanks for the help
There may be a fault in the indicator stalk assembly contacts. I would start there.
I just rebuilt mine and changed it over to right hand drive configuration. It had worn position indents and a broken indent retention spring so when you moved the indicator stalk, it wouldn't stay in position for the turn. Now it works fine.
