Hi gang - Long time...
I just got an EMS Dual Sport for my 75 3.0L.
My questions are-
Has anyone put one in their car, did it work ok…. map sharing?
Where can I get a good diagram of the jetronic pin layout?
I have searched but not much was found, this is a user problem.
Thanks in advance.
- Que Boludo
EMS Dual Sport - Help.
Re: EMS Dual Sport - Help.
If you can get someones Megasquirt or GoTech map, there's no reason why you couldn't add those numbers to the EMS as a starting map.Que Boludo wrote: Has anyone put one in their car, did it work ok…. map sharing?
- Que Boludo
- Que Boludo
WoW!!
This is not the forum I knew some years back....anyone here..Echo..echo...
- SydneyJules
I think the only problem is lack of experience with the ECU, mate!
You're gonna have to try out Aussie mechanics, because the budget Aussie stuff doesn't sell as well overseas- they have their MS and Gotech et al- all pretty along the same lines! The only aussie stuff that really gets the go O/S from what I hear is Haltech, Autronic, and the big M (otech)!!
I still think your best bet is to give V and E Rigoli a bell- at leat he knows about Alfas... bit better than getting some VL Turbo bloke to give it the once over....
