aggarcia
Non US spec cam info needed
Post by aggarcia »
Anybody have cams specs for factory cams left and right 60572874 or 60572873 ?
Thanks for your help.
ANDREWG
1982 GTV6 ITS #63
1988 Milano Verde - Project car
1988 Milano Verde IMSA IS - now SCCA ITE
1991 164S
www.garciaalfaracing.com
These are the cams from the 164 2liter V6 Turbo motor and they have been renamed to 60602873 and 60602874, not a rare cam at all (renaming did not alter specs). Timing: 8*-42*-42*-1*. Lift: 9.1/8.6mm in/ex. These are not suitable for atmospheric engines.
aggarcia
Post by aggarcia »
How well would these work in a 3.0 twin turbo car over say stock Verde cams or S cams? Where can I find more detailed specs like duration, lobe centers, etc? I would hope these would be a better option for a street/track turbo car.
ANDREWG
1982 GTV6 ITS #63
1991 164S
They obviously work well in the 2liter V6 with factory management. Its anyone's guess about the 3liter. These specs should give you all data. Go to AR factory literature for more.
aggarcia
Post by aggarcia »
The only problem is since this chassis and engine combination were never brought into the US, it is not listed in any of the Alfa technical material. I have asked my suppliers and they do not have anything since this was not available through US sources. Could you point me to a webpage or link that may have some of this information?
ANDREWG
1982 GTV6 ITS #63
1991 164S
Andrew,In my experience,the turbo cam will not work well in the 30l..If anything,you can actually go for a slightly "hotter" cam with a turbo.
Now I have not used the 2l v6 cams before,Ive actually not even seen any..If its the same as Alfa`s thinking when it came to the 1800 and 20l 4 cyl. turbo,it will suck performance wise.Now Ive tried the Alfa turbo cam and it gives good off boost drivability-but so did the old 10548 cams with a serious load more up top.
Imo,the turbo cam will choke the potential of your 30l turbo engine.I actually use an old Group1 race profile here on the turbo engines..
Barry, how are the stock 2.5 or 3.0 cams with a turbo? It seems to me the factory cams worked out pretty well on the Callaway car.
Here are some more specs for the V6TB: They use two alternate turbos, Mitsubishi MHI or Garrett T25. CR is 8:1 and valve sizes are 36.4/32.5mm. Timing varies with turbo used (!) and its 37-50-74-29 for MHI and 28-59-65-38 for Garrett. Duration is the same for both, 268*in/284*ex.
These things make 205-210hp and they are routinely chipped for up to 275hp. I don't know how these cams would work on a turbo 3liter, but the great difference in valve size should certainly be a factor to consider! You may have a winner there, who knows; all it takes is a test fit and dyno.
There seems to be some difference from the specs I posted 3 days ago. Those were taken from the factory specs booklet covering the first V6TB version made and timing figures refer to some preset (but not stated!) lift. These may be different than subsequent cars. Today's specs were taken from the official specs and repair Microfiches for the latest 164 Turbo models. All in all, these V6TB's have proved to be durable and potent engines in spite of the outdated management system used which BTW is far better than the one used in the 75 1.8T.
Maurizio
Post by Maurizio »
You could try http://www.squadra-tuning.com/
I read somewhere that the owner self build a 2.8 turbo out of 2.0 and 3.0 parts for in a 916 spider.
The 2.8 Spider has 312 bhp. Not sure if it is his car though. I don't think he mentioned anything about the nokkenassen. He likes the Spider cams better than S cams, but that was all for an NA car (he and a Dutch 155 owner installed it in 155 V6 with good results).
Maurizio
Post by Maurizio »
He didn't mention the "nokkenassen" :lol: only a other turbo.
Greg,very mild...more can be had with near zero loss down below with the grp1 cam..Id shoot for it each and every time unless absolute lowdown torque is essential..Even then Im not sure Id go with std. cam.
aggarcia
Post by aggarcia »
Barry,
Do you have any basic specs for the Group1 cams? The current thought was to use the S cams for this project. I have the option of stock Verde cams, Groupe A cams, Alquati hot street cams ( a little hotter than S cams ), or these V6 turbo cams. Since this will be a street car (inspected and emission dyno’ed) and will be tracked a least once a month, streetablitly is a must. We will be using the Callaway basic setup with slightly bigger turbots and programmable EFI. I would expect peak torque in the 2500-3000 range with peak HP in the 5000-5500. This is the time before the motor is assembled to do a possible cams change. Thanks for your input.
ANDREWG
1982 GTV6 ITS #63
1991 164S
Andrew,I dont.
These cams date from the 80`s when we ran in Grp 1 racing here..If I can remember it was a copy of a CB cam ..
You should know it,its well known for really coming on strong at 4000Rpm..
Did not think Id say this but contact JJ ..He might have in stock..Otherwise pm me your mail addr.
What CR you aiming for and how much boost?Std valves??
aggarcia
Post by aggarcia »
CR is 7.5 with Forged 93 mm pistons, stock valves with ported heads. Boost will be limited to 12-15 lbs. The customer originally wanted to use the microfueler system, but later has decided to go with programmable system.
The Group 1 cams sound a lot like the Groupe A cams. Do they have very short lift 9.6 intake, with long duration?
ANDREWG
1982 GTV6 ITS #63
1991 164S
