While I would agree with you when talking about the later Motronic ECUs, the earlier Motronic didn't even have 3 injector channels or a linear TPS, so there's no way I'd waste any effort making that work with a built NA or force fed engine. Maybe it could work OK, but again, I wouldn't spend the time and money to find out and it would definitely be compromised.Jim K wrote:Truth be told, I don't think any Emerald/DTA/Haltech or other, can make more power than the remapped Motronic. WHY would they? They all have the same kind of maps and comparable resolution. No other hidden secrets. After all, a great many E30 M3's in Germany are seriously raced with their remapped Motronics. I wonder why tuners in the vast US and Australia don't remap std factory ecu's as a matter of fact, something done as a rule in Europe. Here in Greeceland for example, a dyno remap goes for ~400€. If you buy an aftermarket ecu you will pay its price+the custom harness and then 400€ for dyno mapping. Doesn't make much sense UNLESS you are installing efi in an older non-efi or not fully-mappable model like L-jetronic for example. My reason for mapping both Motronic and Emerald for the 3.2 is strictly for the next book (dealing with the 24v and 1.8T). As a preview, I will say that any Alfa 24v (3/3.2/3.5 etc) will always lose to a similar car with a 1.8T engine. I would love things to be the other way around as all my good suspension stuff, thicker tires and close-ratio box is on the 24v and its still 1sec slower than my 1.8T = V6 UNDERSTEER!This is truly a good comparison of engines. Well, they have about the same power 276 vs 272 (for the 3liter) but the turbo has 400Nm torque, no hope to be matched by the 24v. It will be interesting to see how the 3.2 does on track. I do expect it to beat the 1,8T times but then... if the turbo also gets the full RSR, bigger tires and ratios.... Then again, if the turbo is 'allowed' to make ~30 more horses, we will also likely be looking at ~450Nm of torque...
Aftermarket ecu's are necessary for dedicated race stuff, turbo, nitrous and ultra-high rpm as well as other facilities like data loggers, abs, sensor calibration facility, additional inputs/outputs etc. When running turbo+nitrous at 11krpm you want a FAST ecu, that's why people like AEM are so successfull with their Infinity series.
Where's your battery? What front bumper?Jim K wrote:Now let's move on to the chassis. I put the 24v on the scales and here are the numbers with lbs in brackets:
LF: 351(774) RF: 327(721)
LR: 271(597) RR: 287(633) Total: 1233kg (2718lbs)
No driver, no spare, 3/4 fuel
LF: 396(873) RF: 333(734)
LR: 298(657) RR: 304(670) Total: 1331kg (2935lbs)
With driver, no spare, 3/4 fuel ....actual trackday weight.
Let me remind you this is a road car with full 75 Recaro interior, sound system and 8-point rollcage.
Next job will be on a 4-post ramp lift, where while on the scales and with a corpse at the wheel, coilovers will be adjusted until left/right weights are as close as they can be. Forget about front/rear for this pig with a V6!
