First off you are bidding an USED item. Bear in mind that it's 25 years old.
The bodykit here consists of:
front and rear bumper 2pcs
Headlight washer nozzles 2ps
rear hatch spoiler 1pcs
Sideskirts (4pcs total)
bumper mounts 2pcs
Front and rear bumper are made from glass fiber (very light), whereas sideskirts are made from plastic. The rear spoiler is made of rubber like material. (needs good paint prep – paint prone for cracking on this part)
Now there are few flaws concerning the bodykit:
FRONT SPOILER/BUMPER
Apparently one of the previous owners, must have damaged the right part of the front bumper. The result, it's 1-2cm wider on this side than it should be (poorly repaired) this can be easily fixed by a good body shop or similar.
SIDE SKIRT INSERTS
Some of the black inserts are unfortunately missing.
Entire kit needs to be sanded down to base layer, and properly prepped and painted (few layers already).
If you have any questions I'll be happy to reply.
Shipping costs to follow. Bear in mind that this will be rather a big package (approx 195cm x 75cm x 70cm).
Few pics:
