A few weeks back Dave, and I (Martin) Posted that we had stripped two 1984 GTV-6's to finish our respective projects...
Today we had our first parts showing at the auto club event in York Pa, with good result... The folks up there were simply fantastic, and I urge any one in the NE to check it out next year.
That being said ... on to business.... We had a chance to put together a list of larger parts and set initial prices based upon condition, availability, and if available price of new vs used.
All reasonable offers are welcome... and if its not on the list... feel free to ask because these are just the parts we have so far pulled... and not yet sold.
Air intake covers (2) Body Molding $60
Bumper Guard (upper) right/left set $70
Bumper/Rear (tear to Driver Side rubber trim) Body Molding $90
Door gasket w/felt $45
Door handle with lock (driver) $50
Door handle with lock (passenger) $50
Door lock/handle (driver) key is #1835 $50
Door Lock/handle $50
Door lock/handle (passenger) key is #1835 $50
Door Mirror - $75
Floor pan plugs (4) $12
Front air dam (Fair condition) needs cosmetic work $190
Front Bumper w/ bolts $150
Front Grill Body Molding $200
Gas cap with key $75
Gas cap with key (key #8153) $75
Hatch drain tubes (set of 2) $10
Hatch lock/cylinder/catch (with key #1835) $50
Hatchback trunk gasket $55
Hood W/ fiber glass insert $140
Lower body molding (set) $110
Plenum cover - plastic $50
Rear Bumper w/bolts $150
Rear inner fender liner (1 -- check side) $60
Rear triangle trim (driver) bolts and pin intact $25
Rear triangle trim (passenger) bolts and pin intact $25
Rocker Guard (front) right/left $45
Rocker Guard (rear) right/left $45
Side Molding Trim (6 piece set) $50
Trunk lock with key, cylinder, sleeve, latch $50
Vent baffle $15
Windshield washer nozzles $20
Clock (Borg) $50
Gauge Cluster with switches Electronics $70
Injection relay $80
Injection relay $80
Jetronic ECU with vinyl cover $220
Power window winder motor w/cable (set - Driver/Passenger) $140
Relay - courtesy light timer $40
Relay - intermittent $40
Speedometer $50
Tachometer $50
Wiring Harness - rear lighting $50
AC Condenser $75
AC condensor $75
AC evaporator bottle $50
AFM Jetronic $250
AFM Jetronic $250
Air box $40
Air Box $40
Air flow meter $250
Brake booster $350
Brake master cylinder $50
Cam Cogs (2) $100
Cam covers (2) $200
Cam Shaft caps (set) $50
Cam shafts (2) $500
Coolant overflow reservoir $60
Coolant reservoir tank $60
Cooling Fan and Motor w/housing (2) $200
Cyl Heads (2) $400
Distributor and cap $70
Distributor cap (2) $15
Exhaust manifold (2) $250
Ignition coil $35
Ignition wires (6) set black OEM $45
Ignition wires set OEM $50
Intake Hoses (6) set $30
Intake Plenum $50
Intake Plenum $50
Intake runners (6) set/chrome $60
Radiator $200
Radiator $200
Thermostat and housing $60
Throttle body w/ sensor switch $75
Timing belt cover (2) left - right $30
Valve Springs (set) $50
Windshield washer fluid bottle with pump $110
Arm rests with tan insets $30
Battery Cover- Black $15
Center console - tear to vinyl shift boot $45
Chrome sill plate - driver side $25
Chrome sill plate - passenger side $25
Chrome trim/felt for interior of driver window $40
Chrome trim/felt for interior of passenger window $40
Courtesy light - passenger Interior/Trim $50
Dash trim piece around gauges $75
Door Panel - Tan/Black Vinyl (Driver) $60
Door Panel - Tan/Black Vinyl (Passenger)$60
ECU interior panel cover $35
Gear shift knob/black vinyl $20
Horn button $40
Horn button/cover with later AR insert Interior/Trim $55
Interior trim (window winders/tan, etc. $35
OEM Jack $20
Power mirror switch and trim ring $35
Quarter Panel - Tan/Black Vinyl w/ Speaker Hole (Driver) $50
Quarter Panel - Tan/Black Vinyl w/ Speaker Hole (Passenger) $50
Rear hatch gasket $25
Rear seats - bench BOTTOM ONLY- tan leather vinyl $100
Rear speaker covers (2) - original design $45
Rear view mirror - complete Interior/Trim $40
Rear view mirror - missing day/night switch $25
Seat belt bolt covers (upper portion, set of 2) $10
Sunroof gasket (large cream) $50
TropicAire cover (interior) $30
Trunk carpet set $80
Weatherstripping - door, W/o velvet $15
Weatherstripping - rear window (drivers) w/velvet trim $25
Weatherstripping - rear window (passenger) w/velvet trim $25
Window winder tool $35
Front marker lights (amber, set of 2) $20
Headlamp - high beam (2) $25
Headlamp - low beam (2) $25
Headlamps - high beam (1) $15
Headlamps - low beam (2) $25
License plate lights (2) $20
Marker Lights - Front/Amber (2) $35
Marker Lights - Rear/Red (2) $35
Parking/Turn Signal Light (driver) $115
Parking/Turn Signal Light (passenger) $115
Parking/Turn Signal Light w/ lens (passenger) $115
Tail light housing, circuits, lens (driver)/complete $95
Tail light housing, circuits, lens (passenger) complete $95
Door Mirror - Driver Side with bolts $65
Battery bolt down brakets $10
Battery Cover $15
Fuel filler neck and splash guard $30
Fuel tank/fuel filler rubber connector $20
Okay, so that is the list so far... there are lots of parts left to be pulled so if its not here that means its probably still on the car so please send your requests....
Discounts are available for bulk orders.... and are adjusted based upon the attitude of the buyer
We welcome all reasonable offers... we are not parts dealers... just two alfa guys who are trying to give good homes to parts. We tried to be fair, with respect to parts and their availability used or new...
Also, when we are done... we will have two nearly rust free shells that we are looking to sell for $100 each... these would make great project race cars... or a body donor for a rusty GTV-6 (We do have titles for both cars)...
I hope we can all have some fun... and give these parts a good home...
Regards
Martin & Dave
Please send all parts requests to (Alfa_gtv6_parts@yahoo.com) and either Dave or myself with be in contact with you asap.
Photos are available upon request...
Thank you
