I recently got some new rod ends from pitstopusa.com. They are aurora brand, i believe. They are really smooth, but almost loose, it feels a bit like play!
The rod ends that I recently pulled off of my wrecked VW feel much different. They are not so loose, even after years of use on sway bar end links in a salty world. They are smooth and tight.
I feel that if I use the aurora rod ends, i will end up hearing them chatter at some point. What type of rod end do I need to buy next time? (I would like them to feel like the ones on my VW Neuspeed sway bars.
James
Surely not...unless its a split ball,Micke??Micke wrote:Check the mounting instructions.
The rod ends I have also feel "loose" until you put the bolt with the right tolerance through. I recall the bolt should be almost 0.1 mm big. This really tightens it up (and makes assembling and disassembling a bitch).
Ive never come across this before...
