rubber donut for idle
Posted: Wed Aug 17, 2005 4:46 pm
by grega
Help please
Hey guys. I removed the rubber donut that sits between the idle adjustment double nut. And It fell sowhere in the engine.
I'm afraid it's lost for good. Does anyone know where i can get another one?
Greg A
Posted: Thu Aug 18, 2005 2:49 am
by SamW
IAP should have them, I don't see them on the website, but give them a call.
http://www.international-auto.com/
Posted: Thu Aug 18, 2005 5:18 am
by Alfa GTV6 NZ
Is it the one between the plenum and the double nut adjuster?
If so then any correct sized rubber o-ring should do the trick.
The trick with this is when you tighten the adjuster it squashes the o-ring and makes the hole smaller, and so lets less air pass. I'm guessing you all knew that.
I replace mine every once and a while as they can get out of shape or loose their squishyness.
Posted: Thu Aug 18, 2005 8:41 am
by grega
alfa gtv6 Nz
yes that's the one!
Sam thanks for the response!
Re: rubber donut for idle
Posted: Fri Jul 16, 2010 4:51 am
by Romeo69
Hi all,
does anyone have the thickness and the exact size of this donut? Mine has already shrinked and it is difficult to see the right size. I already tried a few ones, but none of them worked well, idle was always difficult to set.
Or does one know where to get them? (other than international-auto)
Thx
pat
Posted: Fri Jul 16, 2010 11:52 am
by grega
Hey pat,
luck for you i made a note of the size before i installed.
I purchased it from I.A.P.
I.D. 5.84mm
O.D 12.70mm
Thickness 3.42mm
Posted: Tue Jul 27, 2010 1:28 am
by Romeo69
Thanks Greg! For anyone else searching them: at IAP they are item #16991.
Regards, pat
Posted: Fri Aug 20, 2010 9:25 pm
by Boazdexter
hello
this is Dexter
and i want to know something good about this topic
and it would be good reply ok
_______________
"Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups
seo pecialist
