Mats wrote:With a burette. Seal the piston to liner with some grease, torque the head down and fill the combustion chamber through the spark plug hole using a burette, stop when you reach the bottom thread.Alfaross69 wrote:JimJimGreek wrote:You've just begun to scratch the surface of hard work! Now you must equalize chamber volumes to the largest one by careful grinding. It may take anywhere up to 4 hours and countless repeated precision measurements! When that is done, you must make sure combustion volumes are equal, by bolting the head to the block with a used head gasket and cc'ing all cylinders in turn, with the pistons at TDC of course. If you have any discrepancies there, start crying, because rod lengths will be at fault. When that is also done, you must decide how much to mill off the head for the desired CR and then worry again about how close your valves are to the pistons!
Would you explain how with the head in place how to measure combustion volume your way.
That's the combustion chamber volume.
Sorry I knew that ! But I had edited my post to read "cc'ing the cylinders" but your post and my edit passed each other in space. I assumed he meant cc'ing the combustion chambers with pistons at top dead centre when he wrote to cc' ing the cylinders. But it begs the next question.How will you determine swept cylinder volume when pop up pistons are used? which is what I MEANT to write,sorry for the confusion. I'm tired ,sorry or is this just bore(area of bore) x stroke formula for volume?
