Engine cuts out some of the time at 5200rpm
Posted: Mon Jun 28, 2010 12:24 am
by kanga
My 1983GTV 6 engine revs out with ease but occasionally cuts out at 5200rpm, as if the rev limiter has been hit, I have replaced, leads, coil, rotor button, distribotor cap, plugs, and checked everything, could it be the ignition module? any ideas appreciated.
Re: Engine cuts out some of the time at 5200rpm
Posted: Mon Jun 28, 2010 3:26 am
Oil in the plug wells?
Engine ground straps?
Posted: Tue Jun 29, 2010 3:08 am
Is the fuel pump up to the job still?
Posted: Tue Jun 29, 2010 5:15 am
by kanga
Yesterday when it hit 5200 and cut out there was a loud bang in the exhaust so I am figuring the backfire is ignition. The car runs like a gem until 5200rpm and maybe only 1 out of 3 times cuts out and missfires at 5200rpm.
I haven't checked the fuel pressure - any suggestions on what sort of gear I would need to check the pressure?
Thanks.
Posted: Tue Jun 29, 2010 12:11 pm
by kevin
Loud bang is definately ignition. Whats the ditributor bearings like
Posted: Tue Jun 29, 2010 9:27 pm
by kanga
Thanks, I will check. Everything is earthed, no oil in plug wells.
