Ok here is some progress but i've got a lot more questions........HELP
I'm not going to use the intercooler yet just the standard airbox but i think later getting the intercooler sealed up and used as a water to air one will be good, but thats later......now
![Image](http://img202.imageshack.us/img202/993/turbonewfittings.jpg)
turbo fittings oil feed
![Image](http://img202.imageshack.us/img202/7449/189.jpg)
oil return (still has to be cripped for right position)
this is the state of my engine bay atm....
Now the questions and i'm still a bit unsure about the fuel system, because i need to have a return line to the tank but the regulator i have only has an inlet,outlet and boost reference port. If i need a return line it should be from the reg' right? If not i thought maybe the return is from the carbies(like a fuel inj sys) but the photo's i've got of two turbodeltas they don't have a return from the carbies and have the same reg' as me??
also have ordered new big end bearings.....
Thanks Matt
Am i the only one working on my engine atm?
