I think this is the Swiss guy's car (Ollie?)
https://youtu.be/lLvgEVYzh78
Re: 75 3.7 vs 996 GT3 Cup
Oktech, Oliver Koertgen.
3.7 24v 436hp at that time.
It's current engine is 3.9 24v and hé is shooting for 500hp. Didn't make it just yet so is changing a few things.
500 bhp should be right, Modified 997 3.9 has about 500. But I suspect at 9000 rpm, you would need a better crank. AHM sells the part. Though a complete Alfa 3.9 with 500 bhp and billet crank, would probably be a lot more expensive then a used F430 engine.
His 75 is an original autodelta group a or something, so already worth a hole lot of money...
He builds most of his owns parts. I think he has a 103 mm bore to get to 3.9l.
This car weighs less then 1000kg, the porsche will be a bit heavier i think.
http://www.ahmotorsports.co.uk/product/ ... shaft-kit/
I'm guessing in parts alone, the engine cannot be less than $15K with the AHM crank. $7-8K with a stock crank.
F430 engine:
http://www.ebay.com/itm/Complete-F430-C ... p3&vxp=mtr
F360 Engine:
http://www.ebay.com/itm/Ferrari-F360-En ... iv&vxp=mtr
Masserati V8/ Alfa 8C 4.7 engines are super cheap, relatively speaking:
http://www.ebay.com/itm/2011-MASERATI-Q ... 8M&vxp=mtr
However I think Oliver builds it out of passion, so I guess he can stretch the money part a bit more and like you said his chassis is has historical significance.
F430 engine:
F360 Engine:
