Alfa Engine including
Head
Sump
Block
Fly wheel
Starter Motor
Turbo and Exhaust Manifold and dump pipe
Inlet manifold with injectors
2Xdissys and Leads 8mm racing custom"
Intercooler + pipes?
plenum +TB?
ECU + harness??
And if you are really paranoid, crank/rods/pistons? valves/cams/springs?
Is this a bit weird or is it just me?
Mats Strandberg -Scuderia Rosso- Now burned to the ground... -onemanracing.com- -Strandberg.photography-
