V6 senzors and MS?
Do the all original L-Jet sensors work with MS (lambda, air temperature, AFM, crank sesor etc. )?
Basically I've used all the stock sensors on my Milano here in the US. We don't have a crank sensor though. To time the ignition, I use the signal from the distributor. Basically I use the stock wire harness and have an adapter harness to my MS box.
FYI, we may have different sensors here in the US. For example, with our Bosch LJET setup, we don't have a crank sensor (that's why I use the signal from the distributor). Elsewhere in the world the Alfa 75 might have Motronic and I can't comment on which of those sensors are usable.
Does that answer your question?
Bill in Maryland
Bill in Maryland
Bill in MD
'88 Alfa Milano Verde x 2
'77 Fiat Spider
'77 Fiat Spider
