Hi!
I've started planning my upcoming megasquirt-installation. Since I will need a proper TPS I wonder which one that would be easiest to use?
I think I read somewhere that the complete throttlebody incl. tps from a 12v 164 will fit the GTV6 bolt-on. Is there any point in using a TB from a 164S (QV)? Larger diameter?
mac74 I don't know if you'd had a chance to look through my write-up on my MSII install if not here's a link.
http://www.alfagtv6.com/bb/viewtopic.php?t=154
I used a Bosch TPS from a Volvo 850 so that should be convenient for you
A simple adapter plate made from aluminium was all it took and it works just fine.
Ok, Murray, I will look into your thread. I guess I could find one or another Volvo in the local scrapyards
What I was curious about was if the 164 TB is a bolt-on fit. I can get one for about $50 complete with tps. Then you wouldn't even have to build the adaptor plate for the tps (not that it seems as a big deal). Then again, maybe the throttle linkage needs modification?
/Marcus
/Marcus
