195/60R15, 205/55R15 or 205/60R15
For performance, which is the the best tire size for a GTV6 with almost stock suspencion with bilsteins or konis, stock gearbox and between 170 and 200hp.
Anyone tried the Pirelli P7 yet??????????
84 GTV6
96 M3
96 M3
Re: 195/60R15, 205/55R15 or 205/60R15
lucass81 wrote:For performance, which is the the best tire size for a GTV6 with almost stock suspencion with bilsteins or konis, stock gearbox and between 170 and 200hp.
Depends on where they are made, i've had good results here with Toyo Vi Mode tires on my 33, it's good and not hiper expensive as french Michelins (best sport tire in my opinion)
Would use the 205/55/15 however, the 205/60 is to overgeared while for good handling out gtv 3.0 here came out with 205/50 as standard. Horribly under geared but great for handling.
I feel the 1st and 2nd gears on the 84 GTV6 to short for street use with 205/55R15. For track use 205/55R15 will be the better option maybe but for street I may try the 205/60R15.
84 GTV6
96 M3
96 M3
For the street I really like 205/60-15 tires. I wonder if 215/60-15 tires will fit. Yokahama makes some in that size.
Do 205/60 15 not scrub on the front guards given the OD is 12mm greater than OEM 195/60 15?
Jason
1983 GTV6 2.8 litre
1983 GTV6 2.8 litre
I know the 205/55/15 on my old GTV went damn close.GTV27 wrote:Do 205/60 15 not scrub on the front guards given the OD is 12mm greater than OEM 195/60 15?
1966 GTV
1982 Suzuki "Bathurst" Katana
What rims do you have?
Ok, 205/60-15 tires fit the GTV6 with no problems, I have used a few different brands in that size, it's never a problem.
It's also possible to fit 225/50-15 tires. I have done that, but the fronts will rub on the castor rods at full lock, and the rear suspension bushings have to be good (i.e. heim joints or poly) or they will rub when the body shifts back and fourth on the watts linkage during hard cornering.
Greg,
www.hiperformancestore.com
www.okinjectors.com
Greg,
www.okinjectors.com
Thanks Greg, is that with standard 15x6 45mm offset rims?
Jason
1983 GTV6 2.8 litre
1983 GTV6 2.8 litre
Yes, that's with stock 81'-84' GTV6 wheels. I haven't used the 1986 wheels, and obviously the 1985 wheels just won't work with these tires.
www.okinjectors.com
www.okinjectors.com
I am running 225/45-17 on my GTV 2.0. I will check offset and post pics if anyone really wants to know!
