Hi,
Any suggestions on how to remove a UCA retaining bolt that is seriously rusted onto the inner part of the bushing? I have sprayed in tons of WD40 and have been tapping the bolt with no success. There is no room for an angle grinder to cut the bolt and I do not look forward to sitting there with a hacksaw blade mounted on a handle. I have purchased new bushings and ball joints and want to get the job of front suspension rebuild done completely.
Brian.
Removing the Upper Control Arm 1986 GTV6
La vita e troppo breve da non guidare un'Alfa
Re: Removing the Upper Control Arm 1986 GTV6
a bit of heat maybe?
Yeah, blowtorch is what worked on mine.
