De Dion Bushing welded, not staked
Hello everyone, need help with my de dion triangle bushing. I'm putting in my rebuilt transaxle and thought I'd put in a new poly dedion bushing I got from AlfaBill when he was going out of business. I expected to see the top side staked in place like I've seen in other postings, but it's welded in:
http://public.bmacfarl.fastmail.fm/#sin ... 520Bushing
I was expecting to have to remove some kind of top ring like you see in the lower right hand corner of the manual ("De Dion Axle Antivibration Bushing"):
http://public.bmacfarl.fastmail.fm/#sin ... emoval.jpg
I'm concerned that this top ring is toast, that's why the bushing is welded in. And the poly bushing has no metal sleave to weld in. The current bushing isn't that bad. Remove the old one or keep it? Any guidance would be appreciated.
Bill in Maryland
Bill in Maryland
Bill in MD
'88 Alfa Milano Verde x 2
'77 Fiat Spider
'77 Fiat Spider
Hi Bill,
It's a little tough to tell exactly what I am looking at in that photo. Here is what I think I see. I think someone changed that bushing and couldn't get the retaining ring back in place, probably because he couldn't push the bushing in all the way. So, to save time, the mechanic put some welds around the perimeter of the hole to prevent the bushing from trying to come out. I don't think the retaining ring is actually welded in place, that wouldn't make any sense. I think the ring is missing.
Whatever the case, this is not a big deal, it's going to cause a little extra work, but that's common on these larger projects.
The new spherical bearing kit from Group2 comes with everything you need including a new retaining ring (it's a "C" type snap ring). The bearing group 2 sells is a little different from the unit sold by IAP and Vick's, but it's high quality and about $100 less! The performance increase over the stock or poly bushing is well worth it.
Hmmm, its this the dedion bearing that requires freezing and cooking and machining, like I see on your webpage:
http://www.hiperformancestore.com/superredverde.htm
I dunno, seems like a lot of work, and I don't have a press.
Bill
Bill
Bill in MD
'77 Fiat Spider
'77 Fiat Spider
I called Group2 today. They are out of the de dion bushings until they can get another shipment from RS Racing. So unless they can get one quickly, I think I'm going to have to try this poly bushing I have.
Does the swiss version really require that much machining, or can I create enough clearance via a brake honing tool?
Bill in Maryland
Bill in Maryland
Bill in MD
'77 Fiat Spider
'77 Fiat Spider
Group2 was out of their spherical bearing dedion bushing, so I went ahead and installed a SuperPro poly bushing (part SPF1830K). Here are some pictures:
Homebrew bushing removal tool:
http://public.bmacfarl.fastmail.fm/bush ... val%20tool
FYI, that's a 2"pipe coupling. The ID wasn't large enough to remove the old bushing, so I put it on a lathe and reamed it out some more. Maybe there are larger pipe couplings out there.
Everything cleaned up and picture of new poly bushing:
http://public.bmacfarl.fastmail.fm/Clea ... %20bushing
Installing the center sleeve:
http://public.bmacfarl.fastmail.fm/Installing%20center
All done:
http://public.bmacfarl.fastmail.fm/Done
Hopefully those pictures are helpful to somebody out there.
Bill in Maryland
All done:
Bill in Maryland
Bill in MD
'77 Fiat Spider
'77 Fiat Spider
