What spring length should I start with? What load rating? I also might need the springs to be a few inches shorter than normal to accomodate helper springs.
The car should be much lighter than stock due to Evo bumpers and lack of AC system and PS pump. The car will be an aggressive street machine retaining stock torsion bars.
The springs will be used with bilstiens and adaptor tubes. I also will make a tubular upper control arm to clear the 2.5in ID springs, so I shouldn't have to worry about upper arm clearance.
I thought I was doing the incorrect conversion.
4in springs, eh? I dont really understand how that would work. I thought that I would set the torsions at the lowest setting and then use the coilovers to raise the car back up to the desired height. I thought I would need an 8 in spring so that I would have some compression to use.
Maurizo-
Could you describe your setup a little bit more? It might save me some effort and time. Thanks for the help.
I got my adaptor sleeves today (from pitstopusa.com). I am at a loss as to how I will attach the sleeve to the shock body.
Now that I have the sleeves in hand, I see that they are made of aluminum. welding does not seem to be an option. I could have a steel sleeve welded onto the shock body, I guess. The alu threaded sleeve would then seat against that.
Does this idea sound like it might work?
Anybody have a better idea?
Greg,
What you said is true. But if you want to keep things under a tight budget, the RSR kit won't meet the budget. I think the whole kit is worth around US$2K at the very least. Obviously, there's a reason why it cost so much, because it's very good and it works.
Alternatively you can just go with a torsion bar based setup. I will be installing my Beninca setup soon. However since this topic is about coilovers, I guess we will have to discount that.
Zambon,
I have a pair of AVO shocks with the threaded bodies. I've had the top portion converted a rod style mount (like stock Alfas). If you want my shocks and springs, PM me. But I would advise that you have it redone properly (just the top part). It uses 1.75" springs so clearence is not really an issue. I even have the lower adaptors to fit the A-arm.
Zambon,
- Maurizio
is glue-ing (epoxy) the sleeve not an option? Have seen it before, sleeves glued over bilstein shocks.
@Zam: Isn't possible to get the avo's with thread from the manufacturer, welding to a shock is not without risk.
Banned.. ?
Daily donky.. ==> BMW 325d
E36M3 (3.0) Ringtool
==> definitely BANNED!
Maurizio,
I think glueing is ok, provided you get the correct epoxy. I think that's what that guy... JB (the 3.0 V6 TT guy from Holland did) on the Bilsteins.
I didn't weld the shock body, just the top of the shaft, and the welding is done in such a short time it doesn't warm up the shaft by much at all. Just extend the shaft and pack ice around it. Welding around the shock body is definitely something I would not even try.
Weld on a flange on the threaded pipe so it will seat on the top on the shock, that way the car won't drop to the ground if the glue fails (at 200Km/h
- Maurizio
Mats wrote:Weld on a flange on the threaded pipe so it will seat on the top on the shock, that way the car won't drop to the ground if the glue fails (at 200Km/h).
Also true, glue is something which can fail if done not thoroughly. I have a set of sleeves laying around and took a look a them a few minutes ago. They have a small step in diameter on the top position, so the can't go through. I don't know their origin, just bought them as a low budget coil-over experiment for my daily driver (when I ever get time
I would mill a circlip groove in the sleeve and make a collar to prevent the shock from going through. And epoxy the ( very good experience with stycast ) assembly.
@z: I think JB was using special koni's.
Banned.. ?
zamani is that you thats ordered the beninca setup. i was there the other day and i heard talk about someone from overseas inquiring about their setup. wise choice my friend
as i have the same setup. i am also in the midst of trying to setup something along the lines of the group a rear adjustable spring platform setup. and also lowereing the rear mount for the shocker on the de-dion.(already done this weekend).
sorry if a little off topic guys.
by the way zamani wat exactly did you end up going for with the setup? schookers,uprights, springs, torsion bars? just curious.
patzo_3l
patzo_3l
