PietereQ
Is this the power mirror harness?
Post by PietereQ »
Hi, I'm just putting the interior back together, and I'm wondering what are these wires for? Guessing power mirror but I'm not sure :oops: Any ideas?
pete
someone messed with your wiring....
PietereQ
Post by PietereQ »
x-rad wrote:someone messed with your wiring....
I gues this stands for "no" ? :lol:
Does not look like standard wiring...have to see where they lead...also, there should be more than 4 wires if left and right mirror involved..
Just carefully pop off door panel and check....
PietereQ
Post by PietereQ »
This is euro gtv6 so only left powered mirror, they go to same harness where much more cables (including the joystick control) are. I'm confused by the wire colors, they're different on the end (on photo), and different on the controller. And no mirror to check :?
pain in the ass, but either test the line or manually follow it....
from the wiring dgm...looks like red is the original harness power lead color from the fuse block (#8)to the switch AND to the mirror motor
