Duk
An Extra Timing Belt Idler For the 12 Valve V6
Post by Duk »
I thought I'd add this here.
I made (I actually stuffed up the shape a bit) a mount to add an extra idler pulley for the 12 valve V6 engines to give the driver's side (right hand drive) cam pulley some much needed extra belt wrap.
The idler is for a Nissan engine and is mounted arse about face 'cause of the mounting sleeve.
75evo
Re: An Extra Timing Belt Idler For the 12 Valve V6
Post by 75evo »
What about the belt length?
Duk
Post by Duk »
The new belt is a T034, and is 142 teeth instead of the original's 134.
