Peab
Air Temp sensor wiring
Post by Peab »
I'm about to ditch the AFM now, after running AFM with flap open until now. I have now a straight aluminum tube with conical filter in place and a generic Bosch temp sensor installed in the tube. I'm running fuel only MS with the standard Bosch harness.
So now i wonder on which pins of the AFM connector should i connect the two leads from the temp sensor ?
enzo
Post by enzo »
Pin 6 and 27...they are numberet on the connector of the AFM
Generic Bosch..Be aware that Boscg make NTC AND PTC sensors..You want to use a NTC sensor..
Peab
Post by Peab »
Thanks guys !
I wasn't aware of the NTC and PTC difference. But luckily i have a NTC type. This one:
http://msnordic.mine.nu/docs/sensors/bo ... _m12-l.pdf
