TS_turbo
Post by TS_turbo »
see driled plate on lower A arm ... attachment point of AR bar links ..
close to inner end of A arm -> less travel of link-> "less stiffnes"
close to outer end of A arm more travel-> more ARbar twist
sorry but english is farrr from my native language :lol: and hard to explain tech things :?
jol
Post by jol »
TS_turbo wrote:see driled plate on lower A arm ... attachment point of AR bar links ..
That was clever, better than welding on a part made to bend :)
shures
RS Sway Bar Links
Post by shures »
Is it a problem that the lower attachment of the link in this set-up is in single shear?
Scott Shure
Ellicott City, Md
85 GTV-6
grant
Post by grant »
Is anyone using the RS rear 3 position adjustable rear bar with his front bar? If so, what size front bar is the best match with his new rear one, the 28mm or 30mm? I have a 3.0 Milano with 27.3 mm T-bars and similar rate rear springs and koni yellows.
Alfettish
Post by Alfettish »
he says go 30mm for a v6 car
grant
Post by grant »
For the track, I'm sure 30mm is best. I'm wondering about real-world driving though. His rear bar is actually 4 position adjustable BTW.
Alfettish
Post by Alfettish »
My roads are pretty good so I'm confident the 30mm won't present a really rough ride.
Just so you know, a 4 cyl Alfetta's front anti-roll bar is 20mm stock, and a 90's is about 22. I measured yesterday.
So going a 27 for 4 cyl would be a huge change anyway.
grant
Post by grant »
I'm still de-bugging my car with shankle springs and 28mm front RSR and 26mm rear adjustable RSR bar.
But what I can say for certain is make sure you install re-inforcement plates on the front (for the 75's atleast) and you might want to re-inforce the rear sway bar mounts, where it attaches to the dedion tube. My car has torn up one of the antisway bar mounts and will have to be welded back together. I'll put a picture up soon.
Alfettish
Post by Alfettish »
Yes, Performatek sells the reinforcement plates I think.
grant
Post by grant »
If you're installing an RSR rear bar on a 75, I think you will find this informative:
http://alfabb.com/bb/forums/showthread. ... post356695
